imjolly
Message 31 of 51
Re: Home Hub keeps resetting and my speed has dropped by half.
there are other posts where checker shows a far lower estimated figure than that actually attained
Jaspero
Message 32 of 51
thats pretty bad man.You know the in's and out very well,I'm sure something is wrong on BT's side
imjolly
Message 33 of 51
the  ticking you can hear on the line could easily be enough for the broadband to keep dropping connection.  have you tried a factory reset of the hub - recessed button on back until lights flash - or are you able to replace the filter to see if that helps.  id the ticking noise on the line if only phone connected - no hub connected
Fumi
Message 34 of 51
I'll try that. Thanks.
Fumi
Message 35 of 51
Thanks to everyone on here for your help but I'm just not getting anywhere at all.
I factory reset it but it's already disconnected six times this morning. That's simply unacceptable.
 I'm just going to ring 151 tomorrow morning and ask for someone to come out and see if something can be done. I've already invested enough time in this and it is a service I'm paying for.
I understannd the need to get customers to troubleshoot but I cannot spend all my time looking through logs and reporting stuff on here.
Thanks again.
imjolly
Message 36 of 51
hope you get help but you can also phone CS 08001114567 and ask for new router if you think it is faulty.  remember that if you get an engineer visit and problem found on your side of test socket then you get charged £129.99 hence why all the test to try and eliminate problems in your home
shamus1
Expert
Message 37 of 51
i had the same thing happen discoonecting loads of times a day,numerous chats to call centres and i even said i think hub is faulty but they were having none of it,they insisited a engineer had to come out and he did and what did he find my hub disconnecting right in front of him,so he got a new hub out of the van plugged it in and no more disconnects for a month or more now,that engineer visit cost bt not me.
imjolly
Message 38 of 51
please keep checking your bills as it often takes a few months for the charge to appear - hopefully it will never appear but better safe than paying £129.99 for new router
shamus1
Expert
Message 39 of 51
my hub was under 12 months warranty so i will be paying nothing?
john46
Message 40 of 51
it will only be free if you are still in contract
