I have just got BT Infinity and a new Home Hub 3 Installed. I have tried to created a new port forwarding rule to open port 4125 for my HP MediaSmart; however although the rule has been correctly created and applied; I am unable to access the MediaSmart and when checked onling the port is reported as closed. I similarly created a rule to open port 20 for an FTP application and again I was refused access and the port was reported as closed.
I was able to use these rules without any problem with the Home Hub 2 and I had no problem accessing the MediaSmart and using the FTP application.
However when I used the rules supplied with the Home Hub 3, I had no port forwarding problems.
Has anyone else experienced similar problems, and if so, found any solutions
Regards
I have exactly the same issue. Trying to set up port forward rule for CoD:Black Ops on PS3. I have created the rule correctly, but when I check the ports using 'PFPortChecker', every single port I check reports as closed!! This means that my NAT type with in Black Ops has changed from Open on old setup (Home Hub v 1.5) to Moderate on new setup (Infinity with Home Hub 3). I'm pretty sure I'm not anything wrong, but I just can not get ports to report as Open. Is there an issue with Home Hub 3?? Any thoughts or help appreciated!
I was able to open port 5001 to allow my Slingbox to be accessed from outside my home network.
It was pretty straightforward to do on the HH3 to be honest.
I will try and see exactly what I did and try to help.
I've added my own ports to the forwarding - works fine. Go into Settings/Advanced Settings/Port Forwarding/Supported Applications
Then, select "Add new game or application", give it a name, choose the protocol, specify the port range (for single ports put the same port number in both boxes, e.g. 873-873), select "Add", then "Apply".
You'll then find that it has been added to the list of known applications.
I did add the ports as instructed by BT and as MikeZ detailed. The new application appeared in the list of known applications and applied to the related computer. However the ports remained closed and I was unable to use the application
Regards
@Legion_Steve wrote:I have exactly the same issue. Trying to set up port forward rule for CoD:Black Ops on PS3. I have created the rule correctly, but when I check the ports using 'PFPortChecker', every single port I check reports as closed!! This means that my NAT type with in Black Ops has changed from Open on old setup (Home Hub v 1.5) to Moderate on new setup (Infinity with Home Hub 3). I'm pretty sure I'm not anything wrong, but I just can not get ports to report as Open. Is there an issue with Home Hub 3?? Any thoughts or help appreciated!
Had same problems after many phone calls to Bt ,I contacted by mistake Bt buisness who told me home hub 3 will not work as it needs a static ip address which the hh3 doesn't support so i changed to BT BUISNESS NEW HUB ON THE WAY!
Hi, I have a similar issue with an O2 Boostbox and a BT Homehub V2. The Boostbox was working fine until I had broadband issues which BT fixed but at that point the boostbox lost connection.
I have spoken to O2 who have investigated and told me it was BT, I have spoken to BT who didn't understand what I was talking about but nevertheless told me to speak to O2.
I am not computer literate put at O2s suggestion downl;oaded some trila software from Port Forward which allows me to check ports but is being blocked by something.
I know from O2 which ports need to be open but cannot find any access into the router to do this.
In the meantime if I climb on my roof I can make a phone call!
