nikev21
Message 11 of 15
Re: Home Network Speeds Using BT Infinity ?
Well the gigabit switch arrived today, I hooked-up everything using cat6 cables and my speeds jumped from 10 MB/sec to  70 MB/sec, (took just over 1 min to copy over a 4.36 GB file on the network). Well pleased with the results, many thanks to all who helped me get there.
Ratty2012
Recognised Expert
Message 12 of 15
Very glad you've got it sorted and you're very welcome 🙂
NewtronStar
Expert
Message 13 of 15
Good Job ! i would be interested in this gigabit switch my self, to backup PC hard drives over the network all I get is 3.5MB/sec
have you a link to the Switch you bought.
The only difference with B computer is I will be using 300Mbit Homeplugs instead of CAT6.
Ratty2012
Recognised Expert
Message 14 of 15
The reason you are only getting 3.5MB/sec is because you are using the homeplug, the only way to get faster speeds is by using the CAT6 cable.
nikev21
Message 15 of 15
*The switch was a TP-Link 5-Port Gigabit Unmanaged Desktop Switch, cost 16 quid on A*****.
* Cat6 Shielded Network Cable, 10 Meters, FTP, Black Ethernet Patch Lead, cost 6 quid on A*****
good luck
