Newbie
Message 1 of 14
Home firewall and server / modem mode + ip changes
I am shopping around for deals and looking at BT.
Currently we have Virgin which does modem only mode and the IP changes not even yearly on consumer.
I have a proper firewall which does routing and that feeds into a mail server - not business.
Can the new hub do modem only or something else, and if you dont unplug it how often does ip change please?
13 REPLIES 13
Message 2 of 14
Re: Home firewall and server / modem mode + ip changes
The BT hubs do not have a modem only mode I'm afraid. Openreach modems are available from the well known auction site. With an Openreach modem and stable connection IP changes will be rare.
Newbie
Message 3 of 14
Can you simply buy one, put password in and use as modem only? Will speed be up to 5*mbps as mentioned for stnd?
Message 4 of 14
Yes, they are plug and play, user name and password are provided by the router at the PPP layer, not the modem and are generic in any case.
Newbie
Message 5 of 14
BT chat person says IP changes as done by exchange not modem.
For just smart hub is there a way of making it work with a business grade utm firewall please?
Message 6 of 14
Obviously, BT supply dynamic IP addresses but as long as you don't disconnect the line the IP address shouldn't change. If you need a static IP address you need a business line.
You can connect it to whatever you like, but it will be performing the NAT and PPP functions and cannot be used as a pure modem.
Message 7 of 14
If you decide to buy an Openreach modem, get the Huawei HG612 version in preference to the ECI.
Newbie
Message 8 of 14
I never unplug or turn it off. I guess if BT went down in the area it may change. If the line quality was poor it may re-set I assume.
Firewall wise I could turn nat off on it. Can you turn off dchp?
Message 9 of 14
You can turn off DHCP but doubt NAT, I don't use a Home Hub so can't check. The Home Hub will definitely cause IP changes as it re-boots every 14 days and BT tinker with the firmware.
Newbie
Message 10 of 14
Ahh, the stnd hub reboots by itself and OpenReach does not?
