messiahbrowny
Message 1 of 2
Home hub 4 Question
Hi all am new
Got a question on the home hub 4 it has a gige4 port what does that do should i plu my ethernet cable in whilst using the xbox?
1 REPLY 1
gg30340
Message 2 of 2
Re: Home hub 4 Question
That is a gigabit port for using with devices that would support that speed. You could plug your xbox into it but it will not go any faster than if you plugged it into any of the other ports because as far as I am aware the xbox can not transfer at gigabit speeds.
