Message 1 of 4
Home hub 5 keeps rebooting ?
17:20:41, 23 Dec.STP Alert: Port eth0 leaving blocking state.
16:16:03, 23 Dec.(173017.910000) The system is going DOWN for reboot.
16:16:03, 23 Dec.(173017.910000) OpenRG is going for reboot by IPC command
16:15:58, 23 Dec.(173012.910000) OpenRG will go down for reboot in 5 seconds
16:11:56, 21 Dec.(111051.150000) The system is going DOWN for reboot.
10:21:49, 20 Dec.STP Alert: Port eth0 leaving blocking state.
01:01:11, 07 May.( 87.220000) The system is going DOWN for reboot.
09:18:38, 20 Dec.(172857.640000) The system is going DOWN for reboot.
09:17:08, 18 Dec.(73832.350000) The system is going DOWN for reboot.
13:47:15, 17 Dec.STP Alert: Port eth0 leaving blocking state.
12:46:00, 17 Dec.(162538.060000) The system is going DOWN for reboot.
15:36:28, 15 Dec.(355230.840000) The system is going DOWN for reboot.
15:36:28, 15 Dec.(355230.840000) OpenRG is going for reboot by IPC command
15:36:23, 15 Dec.(355225.840000) OpenRG will go down for reboot in 5 seconds
01:01:14, 07 May.( 89.580000) The system is going DOWN for reboot.
12:53:20, 11 Dec.(80158.080000) The system is going DOWN for reboot.
14:36:48, 10 Dec.( 5566.120000) The system is going DOWN for reboot.
13:03:25, 10 Dec.(75050.650000) The system is going DOWN for reboot.
16:12:00, 09 Dec.(194004.990000) The system is going DOWN for reboot.
3 REPLIES 3
Message 2 of 4
Re: Home hub 5 keeps rebooting ?
Have you tried a factory reset of your hub using the reset pin hole at the rear of the hub
Message 3 of 4
havent tried that, a wee bit worried that will create bigger problems, log on, wi-fi ect. will it all connect as normal after a re set ?
Message 4 of 4
Yes, it will revert to the setting as shown on the card that came with the home hub.
