Message 1 of 8
Home hub 5 orange light several times a day
A few months ago I upgraded to bt infinity with TV. We often watch Internet TV and haven't managed a full program yet without the internet dropping and the hub showing an orange light before returning to normal after around 3 or 4 mins. At first it was occasional now it's : or 4 times per night. Any ideas? Should I contact BT or is there something I could be doing?
Tags (1)
7 REPLIES 7
Message 2 of 8
Re: Home hub 5 orange light several times a day
was it self install or engineer?
are you connected to test socket?
go to hub manager then troubleshooting then helpdesk and post stats 1-12
Message 3 of 8
Thank you @imjolly
An engineer fitted it, I don't appear to have a test socket but my hub is plugged into the Openreach socket. Here are the stats as requested:
1. Product name:
BT Home Hub
2. Serial number:
+068343+NQ42584389
3. Firmware version:
Software version 4.7.5.1.83.8.204 (Type A) Last updated 16/01/15
4. Board version:
BT Hub 5A
5. DSL uptime:
0 days, 00:31:21
6. Data rate:
7262 / 33478
7. Maximum data rate:
8866 / 41207
8. Noise margin:
6.5 / 8.9
9. Line attenuation:
25.0 / 25.4
10. Signal attenuation:
25.2 / 23.0
11. Data sent/received:
1.9 GB / 35.4 GB
12. Broadband username:
bthomehub@btbroadband.com
13. BT Wi-fi:
14. 2.4 GHz Wireless network/SSID:
BTHub5-XJFH
15. 2.4 GHz Wireless connections:
Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:
WPA2
17. 2.4 GHz Wireless channel:
Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:
BTHub5-XJFH
19. 5 GHz Wireless connections:
Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:
WPA2
21. 5 GHz Wireless channel:
22. Firewall:
Default
23. MAC Address:
c8:91:f9:17:33:24
24. Modulation:
G.993.2 Annex B
25. Software variant:
AA
26. Boot loader:
1.0.0
Message 4 of 8
Sorry but did you notice if openreach engineer or a contractor?
Message 5 of 8
Have you tested your phoneline for any noise?
See this Helpfile  http://support.zen.co.uk/kb/Knowledgebase/Performing-a-Quiet-Line-Test
If everything is quiet then :
Or it could be a faulty HH5 << a persistnt call to support in India should get you a new one sent out (once you have gone thru all their silly tech questions). This would at least eliminate the HH5 as the problem.
Other issues that spring to mind are line interference - this could be caused by an electrical device either within your own home that is switched on/off at the time you disconnect) - or could be in a neighbours home or on the street (like streetlights). These are obviously much harder to diagnose.
As per many other users who have had HH5 disconnection problems perhaps getting a seperate modem may give you more line stability. The recommended modem is the HG612 3B and is available from several online sites. The HH5 just connects to this as a slave device with the modem handeling the line connection.
Message 6 of 8
It was an Openreach engineer
I will do a noise check
Message 7 of 8
Just done a noise checks which was quiet. Is one test enough or do I need to do more?
BTW... Thanks for the help!
Message 8 of 8
if so then there should be a test socket behind the bottom half
