Littlepace
Message 31 of 76
Re: Home hub hasn't arrived yet
I've ordered the one from Argos that was recommended above. Going to pick up now. Are they easy to setup??
Keith_Beddoe
Message 32 of 76
See the link I posted TD-W9970 N300
The info you need is there, its very easy, you just select the ISP  service, and enter the login details, the rest is filled in for you.
pippincp
Sage
Message 33 of 76
Yes, use the smart setup wizard it will do it all for you. Any problems post back but you should be OK.
licquorice
Message 34 of 76
@Littlepace wrote:
Well they know it's BT infinity. I've already told them that. Should I just bite the bullet and go get a router from Argos. They're telling me that there is a fault outside the house... What is this??! We had no issues before how can there now be a fault. Who am I dealing with here.
They don't 'know' that its Infinity, they won't have taken your word for it, they will just accept what their screen tells them you have. I suspect they think you have a fault because they think you still have ADSL and they can't see a modem at the end of your line.
Littlepace
Message 35 of 76
Ok I've got the router installed but I'm not getting any internet still. On mobile when I try and load a webpage I get a BT error page. The tp link page says im connected not sure why it's not working. Any ideas???
Littlepace
Message 36 of 76
The error page says service Information you've been brought here for one of several reasons.
pippincp
Sage
Message 37 of 76
Can you post a screeshot of the connection settings page show we can check everything is as it should be?
Meanwhile I've asked a mod to look in. They may give you the best chat line to speak to to sort this out.
I suspect that although your ADSL has been changed over to Infinity the order hasn't completed.
Keith_Beddoe
Message 38 of 76
At least you have a connection.
Did you enter the correct login details into the router as described on my webpage, otherwise you will get the message you are seeing. What did you enter in this box for the user name and password?
It needs to be:-
User mame bthomehub@btbroadband.com
Password bt
Littlepace
Message 39 of 76
Oh no I entered the admin admin again....i didn't realise... I'll change that and see if that works
Keith_Beddoe
Message 40 of 76
No wonder you got that error code Smiley Wink
It would not authenticate properly.
