Littlepace
Message 41 of 76
Re: Home hub hasn't arrived yet
Ok it's all sorted now. However I'm getting low speeds. I got a decent 22 down and 3 up at first but even that's lower than my promised down of 27 and up of 5. And I'm currently getting 13 down and 1 up. Maybe they were right that I have a fault on the line. Any ideas???
Keith_Beddoe
Message 42 of 76
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
What connection speed  does it say on the TP Link status page?
Webby
Message 43 of 76
Is the router connected to the master socket? Or an extension?
Can you post up a screenshot of the connection stats fromthe router manager page?
Littlepace
Message 44 of 76
BT BROADBAND AVAILABILITY CHECKER
Telephone Number on Exchange DUDLESTON HEATH is served by Cabinet 2
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  HighLowHighLow
ADSL Products
Downstream Range(Mbps)
Availability Date
VDSL Range A (Clean)40.531.97.65.727.4Available----Yes--
VDSL Range B (Impacted)31.816.27.23.711.9Available----Yes--
Littlepace
Message 45 of 76
Line Status:Connected
DSL Modulation Type:VDSL2
Annex Type:Annex A/L
  Upstream DownstreamCurrent Rate (Kbps)Max Rate (Kbps)SNR Margin (dB)Line Attenuation (dB)Errors (Pkts)
126127239
126126865
6.45.5
102.324.2
00
WAN
Name Connection Type VPI/VCI or VID IP/Mask Gateway DNS Status
br_8_35_1Bridge8/35N/AN/AN/AConnected
pppoe_ptm_101_0_dPPPoE10186.137.84.189 /32172.16.16.159194.72.9.34 213.120.234.46Connected
IPv6 WAN
Name Connection Type VPI/VCI or VID IPv6 Address/Prefix Length Gateway DNSv6 Status
LAN
MAC Address:70:4F:57:09:21:4E
IP Address:192.168.1.1
Subnet Mask:255.255.255.0
DHCP:Enabled
IPv6 LAN
IPv6 Address:N/A
Prefix Length:64
Autoconfiguration Type:RADVD
Wireless
Status:Enabled
Schedule:Disabled
SSID:TP-LINK_214E
Channel:Auto(Channel 1)
Channel Width:Auto
Mode:11bgn mixed
Security:WPA/WPA2 - Personal
Max Tx Rate:300Mbps
WDS Status:Disabled
Keith_Beddoe
Message 46 of 76
As @Webby has asked, is the router plugged into the master socket, as your connection speed is slow, and the noise margin indicates no room for improvement the way its connected at the moment
Which one of these matches your master phone socket?
Littlepace
Message 47 of 76
The fourth one is the closest but it doesn't have the opening below the openreach logo. Just the one by the screws.
Littlepace
Message 48 of 76
Keith_Beddoe
Message 49 of 76
That looks like the first one, it has a test socket behind.
Please connect things up as shown below, and see if the connection speed increases.
Littlepace
Message 50 of 76
Ok I'm slightly confused about what needs to go into the test socket. Just the modem lead or the filter that has both phone and modem... sorry if I'm being Stupid!
