Webby
Message 51 of 76
Re: Home hub hasn't arrived yet
The filter goes into the test socket when you've removed the faceplate.
When you remove the faceplate, it disconnects any internal wiring you have which often are is the cause of poor speeds or dropping connections, as they act as an atenna inducing "noise" onto the circuit.
licquorice
Message 52 of 76
You will need to use a filter as a converter, the DSL lead (RJ11) won't fit in the socket.
Littlepace
Message 53 of 76
Ok did that and my speeds on LAN for my pc were still around 15 down and 0.9 up. However my phone on wireless is getting 25 down but 0.5 up. Speeds very similar in test socket. Is that just my speeds now?? Or are BT right in saying there's a fault.
Webby
Message 54 of 76
Can you post the router connection stats again?
Littlepace
Message 55 of 76
Sugar... I should of thought of that. I switched it back over and I've got family working from home so I won't be able to switch it again for a few hours.
Littlepace
Message 56 of 76
Is it possible that these are the best speeds I can get?? It doesn't make sense why my phone can get almost twice the speed of my pc despite my PC being connected via Ethernet
Keith_Beddoe
Message 57 of 76
No, you should be able to get a faster connection speed, which is why you need to look at the connection speed while connected to the test socket
When plugged into the test socket, all extensions that you have, should be totally dead, with no dial tone on them.
If they are not, then the extensions are connected to the wrong place, and will affect your speed.
If there is a wiring issue then BT will fix it for free provided it is reported within 28 days of your activation date.
Littlepace
Message 58 of 76
Ok, I'll check again in a few hours and post back the router stats
Littlepace
Message 59 of 76
My apologies for the delay! I've had a hectic few days and haven't had a good chance to sort this out. I'll give a quick update as to where I am. Spoke to BT about the supposed "Fault on my Line" and we had an engineer booked out for Next monday to come fix it. I then get a call saying that the fault has been fixed from remote and there is no longer a need for an engineer visit, disappointing as I was hoping the engineer would be able to give me a new Hub and help sort out my speeds, Should I request another visit?. I'm still having the same speeds as before. Getting better speeds with my phone when close to the router (About 20-25 down at best), but my PC (Connected via ethernet) is still getting between 10-15 down and about 1.0 upload. Webby, you asked for the router stats when plugged into the test socket and I've got them now. (See Below). I spoke to someone on BT live chat asking if we could have a hub that is actually compatible (Smart Hub 6) to replace this one I've bought from Argos. He told me it would cost £50 pound. Surely I shouldn't have to pay for a new home hub when I've paid for the upgrade and should have had one sent out already. Any help either about my low speeds or getting a new hub is appreciated. Cheers.
Line Status:Connected
DSL Modulation Type:VDSL2
Annex Type:Annex A/L
  Upstream DownstreamCurrent Rate (Kbps)Max Rate (Kbps)SNR Margin (dB)Line Attenuation (dB)Errors (Pkts)
125323286
125328009
6.46
102.324.3
00
WAN
Name Connection Type VPI/VCI or VID IP/Mask Gateway DNS Status
br_8_35_1Bridge8/35N/AN/AN/AConnected
pppoe_ptm_101_0_dPPPoE10186.167.199.201 /32172.16.16.159194.72.9.34 213.120.234.46Connected
IPv6 WAN
Name Connection Type VPI/VCI or VID IPv6 Address/Prefix Length Gateway DNSv6 Status
LAN
MAC Address:70:4F:57:09:21:4E
IP Address:192.168.1.1
Subnet Mask:255.255.255.0
DHCP:Enabled
IPv6 LAN
IPv6 Address:N/A
Prefix Length:64
Autoconfiguration Type:RADVD
Wireless
Status:Enabled
Schedule:Disabled
SSID:TP-LINK_214E
Channel:Auto(Channel 5)
Channel Width:Auto
Mode:11bgn mixed
Security:WPA/WPA2 - Personal
Max Tx Rate:300Mbps
WDS Status:Disabled
Keith_Beddoe
Message 60 of 76
What speed where you promised, as you are slightly under the minimum for range A?
