Littlepace
Message 71 of 76
Re: Home hub hasn't arrived yet
1. Best Effort Test: -provides background information.
 Download Speed
 22.61 Mbps
0 Mbps23.54 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 22.61 Mbps
 For your connection, the acceptable range of speedsis 16.48 Mbps-23.54 Mbps .
 Additional Information:
 IP Profile for your line is - 23.54 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 1.16 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 1.16Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Littlepace
Message 72 of 76
This makes it look as if those are the speeds I should be getting... If that's the case why has BT got my expected speeds between 32-41??
Webby
Message 73 of 76
It’s irrelevant, take no notice of it. You’re not getting the speed you should be.
Littlepace
Message 74 of 76
Ok cool
DavidM
Moderator
Moderator
Message 75 of 76
Thanks for running the test @Littlepace. Please drop me over an email with your details and we'll take it from there. I've made the contact link in my profile available to you.
Cheers
David
XRaySpeX
Recognised Expert
Message 76 of 76
OK, @Littlepace, I've now seen this, your other, thread & it does appear you have a low sync issue. The estimates you were given by BT are those of a Clean line but you actually seem to be getting sync speeds in the Impacted line range.
When you did the BT Broadband Availability Checker what did it say at the foot of the table about Premise environment?
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
