Hi all
Ive had my home hub4 since connection on 24/12/13 and Im desperate for some help !! The only way I can get internet now is to forget the home hub and use a BT wifi hot spot. As soon as i connect either wireless or hard wire to the hub I might just as well walk !! Ive done everything I can - reset the hub more times than Ive had hot dinners - used Bt desktop help - which only works if im connected by hot spot which defeats the object - even waited for an hour and a half for technical help who didnt even understand the problem. Ive used lots of different speed tests including Bt and when I first had the hub speed was around 3mb down and .8 up now its 300kb down and 800 up even when aparrently working ive never seen anything more than 300kb on a download. has anyone got any Ideas as to whats going on or what I can do apart from throw it away as not fit for purpose !! Thanks - Ray
welcome to the forum
can you go t hub manager then troubleshooting then logs and looking for 2 lines together when router connected to internet showing connection speed and noise margin - post when you find them
can you run btspeedtester and when first test completes then run diagnostics and post results please
are you conencted to test socket or somewhere else?
Hi
Thanks for your reply but im old and not technicaly minded so have no idea how to do what you suggested !!
Hi
Ive not reset the hub multiple times in a short time - only since getting it on 24/12 - Ive reset it perhaps once or twice a week to try to get it to actually work.
you need to enter 192.168.1.254 into your browser then enter hub password then go to troubleshooting
test socket is here - is this where you are connected
then you need to go to troubleshooting after entering password for hub manager then go to logs and you are looking for 2 entries when hub connected to internet showing connection speed and noise margin
you need to run btspeedtester and when first test completes run diagnostic test and post results
