ESKIBOY
Message 1 of 2
HomeHub 3.0 portforward
Found a problem with the homehub. Was just port forwarding a few ports for the Xbox. I chose the wrong device. So i removed the port forwarding rules and went to add the right device when i get this error message.
The game or application you’ve selected conflicts with an application () you’ve already assigned to another device.
Please remove the other application or select the same device.
Solutions please?
1 REPLY 1
MooJuice
Message 2 of 2
Re: HomeHub 3.0 portforward
Try disabling the firewall, closing your browser, reopening the browser and re-enabling the firewall.  Then try forwarding the ports again.
I'm dying to know if this actooly works!
