Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
if your attenuation has increased as you say then that is a problem with your conenction and probably line resistence increasing your attenuation which as I said in normal circumstances should remain constant.
are you conencted to the test socket and have you tried a new filter.
is the quiet line test ok?
just got home from a friends after ringing 150 to complain and i thought ehreee we go again... the router rebooted 3 times on the trot...but...but... its been stable for 10mins now AND the phone does not say No Line.
here is the new log which in think is a n improvement, also my line speed has gone frm 5mb to 8
I wonder if calling 150 has spured them to check stuff. they said i need engineer i said ok, if he is free.
Connection Information
ADSL Settings
certainly been fixed as attentuation now down to 12.4 and speed is max for adslmax conenction. what about profile try btspeedtester and see if at 7.15mb
do i need to rong 150 back and cancel the engineer who is due on thrsday.... shall i leave it 24hrs ?
Download speedachieved during the test was - 6.67 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
I would wait the 24hrs as getting an engineer appointment can take a few days sometimes. you can always cancel tomorrow as connection now looks good with correct profile - enjoy
fingers crossed....
quiet test = quiet
wonder what would have happened to casue this so soon after engineer came round few weeks ago and rewired after master socket and lifted speed cap on line
looks like something outwith your home which has now been fixed especially with the halving of your attenuation
hmmmm router just rebooted twice in thr last 10 mins - hope thats just the stabilisation
hope so connection speed still the same?
