Distinguished Guru
Message 21 of 24
Re: HomeHub 3 Wireless connection issue
At this point, if it was me, regardless of the stabilisation period, I factory reset the hub (at midday) tomorrow.
(others may suggest otherwise)
Clearly if the xbox can't even see the BTHomeHub3-**** SSID, but can see BTF/O, then the hub aint happy.
-+-No longer a forum member-+-
iWalden92
Message 22 of 24
But when I have previously reset it the Hub works fine for about a day and then it starts playing up again 😞
How to I go about requesting a replacement as my hub is probably faulty
Distinguished Guru
Message 23 of 24
Try the call centre (they used to dish the hub2 out like sweets) - 0800 111 4567
They should be able to send a replacement hub3 out, plus they'll more than likely ask for the other one back
iWalden92
Message 24 of 24
Thanks for all your help 🙂 , I'll give them a ring tomorrow.
