baconnugget
Message 1 of 2
HomeHub 5 wifi 5ghz issue
Im having issues with my homehub 5 where on 5ghz it will occasionally hang, i have tried resetting the device no joy, this is happening on a HP Envy Laptop and Samsung S5 and Macbook Air.
On the 2.4 ghz wifi it is ok, i have now change the setting to put the 5ghz as a different name so it shows as two different wifi names.
When i turned off only the 5ghz but left on 2.4 ghz wifi i get the orange wifi light on on the box anyone know why?
1 REPLY 1
gg30340
Message 2 of 2
Re: HomeHub 5 wifi 5ghz issue
If you turn off either or both of the wireless frequencies the orange light will come on.
See link
http://bt.custhelp.com/app/answers/detail/a_id/46541/session/L2F2LzEvdGltZS8xNDE1NjQxMjczL3NpZC9kamt...
Make sure that you have turned off "Smart Set Up" on the Homehub. See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
When you gave the 2.4Ghz and 5Ghz frequencies different SSids. Did you check the 5 GHz Sync with 2.4 GHz: is set to NO.
