Message 1 of 3
HomeHub keeps randomly rebooting
Hi all.
I use a HomeHub (just says Model A on the back) looks like this Google image link:
Image result for bt homehub 6
We are both connected via cat 5 cable to the router, with two tablets and two mobiles on WIFI.  The internet is reasonably fast 45-55Mbps when we are on the 76  tier.  However the router will enter multiple reboot fits, where it will reboot (turn orange) then blue, and no more than 2-5minutes later will do it again.  This will happen multiple times at generally in the evening.  After a number of reboots it will settle and work fine till the next time.
2 REPLIES 2
Message 2 of 3
Re: HomeHub keeps randomly rebooting
Try quiet line test  dial 17070 option 2 should be silent and best with corded phone using test socket
Post stats  advanced setting then technical log information
Message 3 of 3
Hi @Nioreax,
Welcome to the community and thank you for posting.
If you're seeing your connection drop regularly, it could indicate that there is a fault on the line. If you can try the steps suggested by @imjolly this will help to identify what's causing the instability on your line.
PaddyB
