Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hi all,
I've been having issues with my HH6 for the past month or so where it keeps resetting for no reason every day or so.
Some history:
I experienced a massive slow down in speed (from 8Mb to 0.25Mb) just after Christmas and eventually got an engineer to call. He put me a new master socket in and things returned to normal for a week or so. The speed of the line actually increased to around 9Mbs.
Unfortunately, I then started to experience random disconnects and reboots of the HH to a point where it was going a few times a day. I got another engineer to come out, as there appeared to be quite a bit of noise on the line, but on the day of his visit, the noise had disappeared and it was pretty much a pointless visit for him. He did some tests but he said all looked fine from the socket to the exchange.
So now, the connection is stable for a few days and then for no reason the HH seems to reboot. It always appears to be in the evening between 19:00 - 21:00. I've looked on the logs on the HH and it says "power reset" or words to that effect. This seems a bit strange as the router is in a cupboard and no-one touches it.
Anyone any ideas as to what might be causing this? I do have a second HH6 which also seems to do the same behaviour. Is it worth buying a non-BT router?
John
are you connecting to the test socket with a filter and see if that stabilises your connection - i understand you have a new filtered socket when in test socket checkt that there is no dial tone at any extension socket whether in use or not
can you post hub stats - advanced settings then trechnical log information
any noise on quiet line test?
>>are you connecting to the test socket with a filter and see if that stabilises your connection - i understand you have a new >>filtered socket when in test socket checkt that there is no dial tone at any extension socket whether in use or not
It is a new filtered socket and will check the lack of dial tone when connected to test socket.
Will do when I get back tonight
Nothing of any note. There was a period of time when it was noisy but that seems to have gone away now.
John
Here's the Technical Logs
BT Hub 6A
+084319+NQ73517431
SG4B1000B522
21-Jan-2018
1.0
1.64.0
0 Days, 23 Hours 33 Minutes 7 Seconds
1.26 Mbps / 10.96 Mbps
1264 / 11632
5.7 dB / 2.8 dB
39 dB
24 dB / 39 dB
0/38
G_992_5_ANNEX_A
Fast Path
596 MB Uploaded / 3422 MB Downloaded
bthomehub@btbroadband.com
Active
BTHub6-6WQR
Smart (Channel 6)
BTHub6-6WQR
Smart (Channel 36)
WPA2 (Recommended)
Mode 1
On
58:90:43:B0:01:1B
7.33.1
Also, can confirm no dial-tones from sockets once using test socket.
Hope all this info helps
John
are the stats when connected to test socket?
BT Hub 6A
+084319+NQ73517431
SG4B1000B522
21-Jan-2018
1.0
1.64.0
0 Days, 15 Hours 12 Minutes 56 Seconds
1.28 Mbps / 11.50 Mbps
1284 / 12860
5.9 dB / 3.7 dB
39 dB
24 dB / 39 dB
0/38
G_992_5_ANNEX_A
Fast Path
4422 MB Uploaded / 7061 MB Downloaded
Active
BTHub6-6WQR
Smart (Channel 6)
BTHub6-6WQR
Smart (Channel 36)
WPA2 (Recommended)
Mode 1
On
58:90:43:B0:01:1B
7.33.1
so ok just mnow with 15hrs connection time - just momitor and see if stay stable
It's just gone again now whilst connected to the test socket on the master socket
Time was 1957 and reconnected at 2001
BT Hub 6A
+084319+NQ73517431
SG4B1000B522
21-Jan-2018
1.0
1.64.0
0 Days, 0 Hours 10 Minutes 20 Seconds
1.27 Mbps / 11.72 Mbps
1268 / 12796
5.9 dB / 3.2 dB
39 dB
23.9 dB / 39 dB
0/38
G_992_5_ANNEX_A
Fast Path
2 MB Uploaded / 12 MB Downloaded
Active
BTHub6-6WQR
Smart (Channel 6)
BTHub6-6WQR
Smart (Channel 36)
WPA2 (Recommended)
Mode 1
On
58:90:43:B0:01:1B
7.33.1
This was in log at time of disconnect and I certainly didn't do a power reset
00:00:35, 01 Jan.
:The Modem has successfully powered up
00:00:35, 01 Jan.
:WDG Laststatus:: # Current boot was caused by Power Reset
00:00:24, 01 Jan.
:WAN: ethernet as LAN
19:56:33, 01 Mar.
eth1:IGMP join received for group 235.1.1.1 on interface eth1
