NorthstaNder
Message 1 of 7
Homehub 3 "disappears" from Network
Hi,
Had Infinity for a week now, and so far so good.
But this Homehub 3 thing bugs me a little bit. I've connected my external USB 2.0 hard drive to it, so everyone on the network can use the drive. But when I double click the network icon, the Homehub doesn't always appear under the "computer" section which is where it would appear so I can access the drive.
It appears under "network infrastructure" and "other devices" and access to the internet isn't affected.
Is this just another homehub 3 bug? I do find that restarting the hub sorts it out, but I don't want to keep restarting it every day if I can help it.
Thanks in advance.
6 REPLIES 6
NorthstaNder
Message 2 of 7
Re: Homehub 3 "disappears" from Network
If it makes any difference the drive is formatted to ntfs
Deathtrap3000
Recognised Expert
Message 3 of 7
Its not a bug.
Just type in the address
\\192.168.1.254
NorthstaNder
Message 4 of 7
Aha...works a treat. Thanks!
Do you think I should stick with the NTFS file format? Or reformat to FAT32 if I'm going to be using the drive over the network.
Distinguished Expert
Message 5 of 7
fat32 may work better
how big is the disk as windows has a problem formatting large disks
http://www.ridgecrop.demon.co.uk/index.htm?fat32format.htm
NorthstaNder
Message 6 of 7
It's 750GB with two partitions so I'm probably best sticking to NTFS I guess.
Message 7 of 7
that utility will allow you to format it as fat32
