alsie
Message 1 of 5
Homehub 3
Does the HH3 go into standby mode automately when not in use.
4 REPLIES 4
jjgraphics
Recognised Expert
Message 2 of 5
Re: Homehub 3
Only if you set it to do so. Check out the USer Guide that came with the device.
Distinguished Guru
Message 3 of 5
Re: Homehub 3
If you mean in to power save mode, then yes it does automatically after 5 mins of inactivity - http://bthomehub.home/help.htm#B_ENERGY
-+-No longer a forum member-+-
alsie
Message 4 of 5
Re: Homehub 3
Thanks DS that's what I needed to know.
Distinguished Guru
Message 5 of 5
Re: Homehub 3
No probsSmiley Happy
