jsac
Message 1 of 2
Homehub 5b reset/loss of sync
Hi all,
recently started using the homehub 5b and i noticed last night it had reset and resynced without my intervention. I checked the logs:
these are from TR069 which are happening egzactly every night at the same time, not sure what these are, and why are they hapening every night?
23:35:53, 17 Sep.CWMP: HDM socket closed successfully.
23:35:53, 17 Sep.CWMP: HTTP authentication success from pbthdm.x.x.x
23:35:53, 17 Sep.CWMP: HDM socket opened successfully.
23:35:53, 17 Sep.CWMP: session completed successfully
23:35:52, 17 Sep.CWMP: HDM socket closed successfully.
23:35:52, 17 Sep.CWMP: HTTP authentication success from pbthdm.x.x.x
23:35:52, 17 Sep.CWMP: HDM socket opened successfully.
23:35:51, 17 Sep.CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
23:35:50, 17 Sep.CWMP: Session start now, server: pbthdm.x.x.x, Event code:
23:35:50, 17 Sep.CWMP: Initializing transaction for event code 2 PERIODIC
and these are the ones connected with my loss of sync and reset:
00:22:45, 18 Sep.WAN connection PTM connected
00:22:44, 18 Sep.PPP IPCP Receive Configuration ACK
00:22:44, 18 Sep.PPP IPCP Send Configuration Request
00:22:44, 18 Sep.PPP IPCP Receive Configuration NAK
00:22:44, 18 Sep.PPP IPCP Send Configuration ACK
00:22:44, 18 Sep.PPP IPCP Receive Configuration Request
00:22:43, 18 Sep.PPP IPCP Send Configuration Request
00:22:43, 18 Sep.PPP CHAP Receive success : authentication successful
00:22:43, 18 Sep.PPP CHAP Receive Challenge
00:22:43, 18 Sep.PPP LCP Receive Configuration ACK
00:22:42, 18 Sep.PPP LCP Send Configuration ACK
00:22:42, 18 Sep.PPP LCP Receive Configuration Request
00:22:42, 18 Sep.PPP LCP Send Configuration Request
00:22:33, 18 Sep.WAN connection PTM disconnected
00:22:29, 18 Sep.PPP LCP Send Termination Request (User request)
00:22:26, 18 Sep.PPP LCP Send Termination Request (Peer not responding)
i havent lost any speed as yet, but im wondering what the heck is going on?
totally unprovocked attack - is this DLM showing off a bit ?
1 REPLY 1
JohnC2
Moderator
Moderator
Message 2 of 2
Re: Homehub 5b reset/loss of sync
Hi @jsac Sorry you are experiencing loss of sync with your broadband connection.
Have you noticed if the hub lights change colour when this happens?
As it happens at the same time every night have you checked if there are any devices that are connected to a timer that activates around the same time?
Cheers
John
