spuckle
Message 1 of 11
Homehub Ethernet issues
I have the old white Homehub and WiFi works fine but the Ethernet ports have stopped working. I first suspected the powerline adapters, then my switch, but even connecting direct to the hh there's no connection happening thru either port. Any further ideas of anything I can try before going thru the helpdesk hell?
10 REPLIES 10
john46
Message 2 of 11
Re: Homehub Ethernet issues
Hi
I am sorry to see you are having problems
I suggest you contact live chat at this link they should be able to help you
http://bt.custhelp.com/app/contact/c/2902/?s_intcid=con_intban_sanda_contact_us_chat_from_forums
Devon_Dave
Distinguished Guru
Message 3 of 11
Hi
Have you tried a powerdown of the hub? or trying a different ethernet cable?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Keith_Beddoe
Message 4 of 11
Dave,
The link John gave was for Live Chat, not the mods. The only problem is that Live Chat mainly deal with accounts and orders.
The helpdesk number that you gave is the best choice.
spuckle
Message 5 of 11
Yes, I've powered down and tried multiple cables- and multiple hardware BT Vision, laptop, smart BluRay player etc
Keith_Beddoe
Message 6 of 11
Have you tried a factory reset, as its possible that the user.ini  file has got corrupted?
That file is executed on startup, and maps out the Ethernet ports, and lots of other things as well.
spuckle
Message 7 of 11
I'll give it a go tonight, cheers.
spuckle
Message 8 of 11
Factory reset didnt work 😞 Any other ideas or is Helldesk my only option?
Keith_Beddoe
Message 9 of 11
If you are sure that your Ethernet cable or network port are not faulty, then it looks like the helpdesk.
Have you tried using a different computer? Also check that your Ethernet port on you computer has not been disabled, its very easy to do by accident.
Look under network connections for your Ethernet card, and make sure its not got a cross through it.
spuckle
Message 10 of 11
Yeah tried multiple hardware. Helldesk it is...! Cheers.
