Distinguished Guru
Message 191 of 202
Re: Homehub rebooted - Now have 30MB instead of 70Mb speed
The engineer improving cabling anywhere is certainly not a bad thing though, so maybe he just checked everything he could both at the cabinet and exchange while he was on the job?
Distinguished Guru
Message 192 of 202
By speed I really meant both speed and reliability/stability.
If something somewhere was resulting in additional noise/interference on the copper section between the cabinet and home then that could cause problems with the broadband. That section is carrying both your voice calls signal and broadband signal on different frequencies.
Message 193 of 202
Fingers kept tightly crossed! Although i do believe it won't change much.
Side note, below are my tests + router info from today. Everything look ok on the router side of things do you think?
5288556133
144455815
Message 194 of 202
5288556133
144455815
Looks normal, you are getting max sync rates anyway. I wish I had your line!
If you want to say thanks for a helpful answer click the ratings star on the left-hand side. If the reply answers your question, mark as ’Mark as Accepted Solution’
Message 195 of 202
If it keeps dropping you can have it!
If not then i'll keep it ty
Message 196 of 202
NOOOOOOOOOOOOOOO!
Two days of uptime and i was starting to get cocky - then BAM! it dropped today!
I've copied the below from the Event logs - it looks like it was requested to go down? Can anyone advise?
Message 197 of 202
what is the connection speed now
Message 198 of 202
Hi John,
Same as before i believe:
Message 199 of 202
Hi All,
It looks like the issue has been solved with the last engineer visit. Whatever he did appeared to have sorted it out for me and the line has been stable now for almost 6 days with no issues what so ever
I'd like to thank everyone that's helped - it's been a long running issue but i'm incredibly happy that it looks like it's solved 🙂
Message 200 of 202
 Looking good
