Message 1 of 9
Homehub6 and no ethernet connection
Hope someone can help.
Have a Homehub6 and it is boradcasting WiFi with no problem but it is not "seeing" any of the wired ethernet connections in the back of the router.
Have tried different ethernet cables and even tested a single cable in each port and then refreshed the homehub manager - still notihng "seen".
BT have sent me a new Homehub and it is doing exactly the same - no wired connections seen.
Any ideas out there and thanks in advance for any help.
8 REPLIES 8
Message 2 of 9
Re: Homehub6 and no ethernet connection
what firmware build are your hubs on also are the devices you are connecting able to access the internet
Message 3 of 9
Hi John46
In answer the SkyQ box is connected to the router but is not pocking up the internet.
Don't know how t find out what firmware is running - can you tell me how and then I can post?
Message 4 of 9
it is on the hub help desk page
Message 5 of 9
could you try another device other than the sky q box as it could be the sky box and not the hub as the chance of two hubs having the same fault is unlikely
Message 6 of 9
I also have a mobile hone signal booster box - that is also not working.
Message 7 of 9
Sorry but struggling to find that page.......
Message 8 of 9
enter 192.168.1.254 into your browser address bar then find advanced then locate help desk and post those results
Message 9 of 9
John
Still struggling with this.
Have managed to get the ethernet connections working now but still struggling with the SkyQ box.
Sky "sees" the WiFi network and connects to it but cannot access the internet.
