Message 1 of 4
How Long Does It Take to Disable BT Fon?
Hi
I opted out of the BT Hotspot scheme about 2 weeks ago, in the hope that it would de-activate 'BT FON' services on my router. I see that BT FON is still active.
How long does it normally take to de-activate BT-FON?
Thanks.
3 REPLIES 3
Message 2 of 4
Re: How Long Does It Take to Disable BT Fon?
I would have thought 2 weeks should have been enough. Did you try restarting he hub?
Message 3 of 4
Hi ImJolly
Just restarted the router, and BT-Fon and Wifi-X is still being transmitted from my router. I can tell it's from my router as all the SSID digits match (except the last one.)
Thanks.
Moderator
Moderator
Message 4 of 4
Hi @winner6060,
I'm sorry you're having problems disabling BT WiFi (Fon). I'll be able to check to make sure is been correctly opted out on the network side of things. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
