Message 1 of 2
How Long should I give Speeds to settle?
After a long chain of horrific service spanning 6 months, I finally got FTTP installed and switched on yesterday.
Once I received my email confirming the switch, I did a speed test and got 480 download. Later that evening and now this morning, I have tested again and only getting 25-50 download. Similar story with uploads was over 100 yesterday lunchtime but now varies significantly each test between 20 - 80.
Should I give time to settle or is something not right?
1 REPLY 1
Message 2 of 2
Re: How Long should I give Speeds to settle?
How are you testing, wired or wireless? Which speed tests are you running?
