Message 11 of 14
Re: How accurate is the speed checker?
Just done another BT speed test, this time the upload is working
Download speedachieved during the test was - 7961 Kbps
 For your connection, the acceptable range of speeds is 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :9932 Kbps(DOWN-STREAM), 1142 Kbps(UP-STREAM)
 IP Profile for your line is - 8762 Kbps
>Upload speed achieved during the test was - 947 Kbps
 Upstream Rate IP profile on your line is - 1142 Kbps
Message 12 of 14
hi could you post the full hub stats including connection time an connection speed please as that is needed as well as the speed test
Message 13 of 14
OK
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 13:09:08
Downstream10,846 Kbps
Upstream1,159 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)3.8 dB / 6.1 dB
Line attenuation (Down/Up)35.0 dB / 18.7 dB
Output power (Down/Up)0.0 dBm / 12.6 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)60530027 / 0
CRC Errors (Down/Up)462 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)178
 Download speedachieved during the test was - 8507 Kbps
 IP Profile for your line is - 9569 Kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
Note: An Upstream test was not conducted on this line due to a technical issue. If your concern is related to upstream performance then please retry
the performance test again in 1 hours time.
Question: Why does the IP profile keep changing? Surely that is set?
Message 14 of 14
Hi your ip profile follows your connection speed the higher your connection speed the higher your ip profile goes
