Message 1 of 6
How are my hub stats looking??
After some issues with my line which are now sorted my speeds have not improved but then the hub has not restarted. I'm being patient and not forcing a reboot myself.
I beleive that there is room for improvement as we have had Downstream speeds upto 30+mbps before.
Looking at the stats is there anything i might be able to do to improve matters or do the stats indicate any issues?
Product code:Smart Hub 2
Firmware version:v0.17.01.12301-BT
Firmware updated:Sat Mar 14 19:19:44 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:24 days,19 Hours02 Mins19 Secs
Data rate:3.695 Mbps / 22.398 Mbps
Maximum data rate:4.330 Mbps / 30.825 Mbps
Noise margin:7.6 / 11.6
Line attenuation:11.9 / 26.6
Signal attenuation:11.9 / 27.3
VLAN id:101
Upstream error control:Off
Downstream error control:Off
5 REPLIES 5
Message 2 of 6
Re: How are my hub stats looking??
with 24 days stable connection I would have expected noise margin to reduce and connection speed move nearer attainable.  just leave connected and I have asked mods to see if they can help.  mods are busy so may take bit longer than normal for mods to get back to you
Message 3 of 6
@imjolly Many thanks. I'm not overconcerned just following up on the issues from 3 weeks ago. I understand the stats normally get better over time and see what happens.
Message 4 of 6
Well just thought i'd provide an update.
A few days later and my hub had rebooted and the speed was much improved.
Little while after that the firmware updated and 8 days later here we are:
Firmware version:v0.17.01.12312-BT
Firmware updated:Sat Jul 4 15:23:45 2020
Board version:R01
DSL uptime:8 days,06 Hours38 Mins43 Secs
Data rate:3.695 Mbps / 27.399 Mbps
Maximum data rate:4.568 Mbps / 31.607 Mbps
Noise margin:8.0 / 7.4
Signal attenuation:11.9 / 27.2
Much more in line with previous speeds.
Many thanks again.
Message 5 of 6
looking better and I still think there is a bit more speed to come as actual moves nearer attainable and noise margin goes down to 6db
just stay connected
Message 6 of 6
I will although might be difficult as decorating the house...
However i have had 29-31 Mbps before for a few months, but this is a great improvement.
Thanks again
