Embraer
Message 81 of 503
Re: How can I find my cabinet number and when it will be enabled?
That is with the gods, just keep checking the BT Wholesale checker
zonker84
Message 82 of 503
Anyone have any information on DH5 0LA ?
The postcode checker here: http://www.superfast-openreach.co.uk/where-and-when/
says "accepting orders" but checking my phone number on BT's website still says it's unavailable.
gpfradgley
Message 83 of 503
I'm on the Knottingley Exchange at WF11 8HF and I'm really close to the towns Exchange. Do you know what phase I'm on? Thanks
Embraer
Message 84 of 503
Looks like you're connected directly to the exchange so FTTC isn't an option for you. There is talk that eventually direct lines might be fibred up but you're out of luck at the moment
creeve15
Message 85 of 503
Can you tell when FTTC will be available for SN11 9UN?
I have a feeling that half the postcode has got FTTC and the other half hasn't
Chris.
Webby
Message 86 of 503
100% of cabinets in SN11 9UN are connected to the same cabinet, cabinet number 23. It's going to be FTTC enabled if it's not already (latest spreadsheet).
Have you had a walk around to see if you can find your cab? There'll be a newer, greener one very close by if the cab has already been installed.
dazzybabe
Message 87 of 503
"The postcode checker here: http://www.superfast-openreach.co.uk/where-and-when/
says "accepting orders" but checking my phone number on BT's website still says it's unavailable."
I get the same here. I'm guessing it means that it's more or less ready and they're just waiting for the final switch on or something.
Upbeat
Message 88 of 503
I live in the Streetly area which will shortly be getting infinity - lots of activity in the streets at the moment! When the upgrade happens will standard broadband speeds increase as well? We currently get around 4.2mps download and am hoping it may increase a bit when Infinity is enabled.
Infinitechris
Expert
Message 89 of 503
Installing fibre to the cabinet will have no effect on your current broadband speeds as these will continue to use the copper cabling to the exchange. You will have to order a fibre connection like Infinity to see any gain.
Crashst3r
Message 90 of 503
Aint streetly already active, thought openreach announced its accepting orders since the 27th Feb.
