Martin123
Newbie
Message 1 of 21
How can I stop broadband phone ringing with landline number?
If you call the broadband number only the broadband phone rings - which is what I want.
But when you call my landline number both the landline phone and the broadband phones ring. I want just the landline phone to ring when you call the landline number.
In the settings section of the Hub Manager, for phone sockets it only has two options to choose from:
- BT Broadband Talk only
- BT Broadband Talk and landline
I need one that says "landline only" but there isn't one!
What do I need to do so only the landline rings when the landline number is dialled?
20 REPLIES 20
Message 2 of 21
Re: How can I stop broadband phone ringing with landline number?
Martin123
Newbie
Message 3 of 21
Many thanks - that's worked. Had tried it before but you need to reset the hub for it to work.
alantragen
Newbie
Message 4 of 21
I have been unable to locate the solution to this problem! How do I find it?
Distinguished Guru
Message 5 of 21
Hi alantragen and welcome
You need to change thsi via the hub manager
Enter http://bthomehub.home/ into your browesr.
Click settings (you will need to either change the default admin password (if it's the first time you've accessed it) or input the one you've already chosen)).
Nativgate to Telephones.
The menu is as displayed in the first post.
-+-No longer a forum member-+-
macneill
Newbie
Message 6 of 21
Followed your instructions but no options existed to control which phones rang
What could be different?  As the hub is brand new, could there be software differences?
Previous white hub worked a treat!
Distinguished Guru
Message 7 of 21
Hi macneil and welcome
Try this method
Enter http://bthomehub.home/ into your browser
Click A-Z (top right of Hub Manager window)
Click Activating BT Broadband Talk
You'll now need to enter your password
Then select which phone rings for which type of call
Click Apply
Does this help?
macneill
Newbie
Message 8 of 21
Sorry
It didn't work
As I stated earlier, the hub firmware only seems to have 2 options
I've grabbed a screen image of the options available but can't attach that sorry
Must be a firmware difference on my hub and yours (I guess)
Thanks anyway
Tags (1)
Message 9 of 21
Look at the top of this message thread at the post by martin123, underneath there is a line which says "Go to solution"
Its the "broadband talk only" option.
macneill
Newbie
Message 10 of 21
Many thanks for the quick reply and for your enduring patience
I followed your instructions and they take me back to the original screen with only two options per line
a) broadband and landline ring or
b) broadand rings
There is no option c) landline only
This third option DOES exist on my old white hub but not the most recent hub
Thank you for your help
I believe the only recourse now is to return the hub and cancel the service.
I  might have better luck with Virgin
Bye
Tags (2)
