Distinguished Guru
Message 11 of 21
Re: How can I stop broadband phone ringing with landline number?
@macneil
If you wish to stop the hub phone from ringing when your landline number is called, set the hub phone to ring on Broadband Talk Only.
As per
-+-No longer a forum member-+-
Message 12 of 21
You question was "How can I stop broadband phone ringing with landline number?"
The answer is b) broadband rings.
That is what you wanted.
macneill
Newbie
Message 13 of 21
thank you again
Yes, this is the screen and those are the options
There is no facility to have just the landline ring
Many thanks once again but BT just doesn't seem to have the option I need so I'll have to cancel I suppose
I'm still within the cooling off period.
Thanks again for your help
Tags (1)
Message 14 of 21
That was not the original question.
If you disable Broadband Talk, then the broadband phone will default to the landline, assuming that you do not want to use Broadband talk.
Distinguished Guru
Message 15 of 21
If you follow the screen above, your landline phone will only ring if your landline number is called.
Also, the hub phone will ring if your broadband talk number is called.
Finally, as the service is now active, there is no cooling off periodSmiley Sad
bigbarper
Message 16 of 21
Smiley Sad
Are you sure?
I would interpret that as Phone socket (ie Landline) Broadband (hub Phone) and land line ring which unless I am mistaken is not what is wanted.
How do you get JUST the Landline to ring when the landline number is called, that option does not exist?
Phil.
bigbarper
Message 17 of 21
NOT SOLVED!!!!
Distinguished Guru
Message 18 of 21
@bigbarper wrote:
Smiley Sad
Are you sure?
Phil.
Yes I'm sureSmiley Happy
My set up:
Hub phone registered to the hub
Landline phone plugged in to a standard phone socket
(telephones set as per earlier image)
If my broaband talk number is called, then ONLY my hub phone rings
If my landline number is called, ONLY my landline rings.
Your not plugging your landline phone in to the hub phone socket (back of hub) and only wanting it to ring for landline calls are you?
If you are then obviously that phone will ring on both types of call or just VOIP as this connection is for VOIP, it's not a standard landline connection.
bigbarper
Message 19 of 21
DS hi
My set up is as per yours, ie Landline plugged into standard phone socket, and another phone plugged into the socket at the back of the Hub.
My hub 2.0 does not have the phone (hub phone I guess) attached to the front.
Perhaps that is why I am unable to register the phone plugged into the back, and am not getting the extra ring option line on the setup page.
Phil.
Distinguished Guru
Message 20 of 21
Hi Phil
I don't have a 'normal' phone plugged in to the rear of the hub, I use a BT Hub Phone.
Because you have a 'landline' phone plugged in to the back of the hub, it acts like a hub phone
(it's not actually a hub phone)
To acheive what you want (to stop a phone that is plugged in the rear connection on the hub from ringing on both types of calls), you really need to obtain a hub phone.
(that way, you'll be able to set your phones as per mine).
As a test, I have just plugged a standard phone in to the rear of the home hub and this rings for both types of calls (voip or landline). This is to be expected.
