Redbullracer
Message 1 of 6
How do I get Interleaving disabled and fastpath enabled ?
Hi just wondered if someone can help. My broadband used to work perfect up untill a few faults appeared on the line. The faults have now been rectified and one of the broadband engineers told me the line was set for fastpath and that was wrong for the line and has set it to interleave. Now that he has done that my ping when trying to play online games just goes crazy and it makes games unplayable. I have spoke to BT over the phone and they my (Case Manager) tell me that they don't know what I'm talking about and can't help me. I have been gaming on this connection for the past 5 years with no problems up until 6 months ago when the faults developed. My case manager says the speed I get on the line which is a MAX of 3.6mb is no good for gaming which I have told her that it was never an issue untill the faults happened and the engineer switched it over to interleaving. So can someone on here help me out ? What info do you need and how long does it normaly take ?
Regards
5 REPLIES 5
JohnC2
Moderator
Moderator
Message 2 of 6
Re: How do I get Interleaving disabled and fastpath enabled ?
Hi @Redbullracer Sorry you could not get the Interleaving removed when you called us.
Drop us over your details and we will be happy to get you moved over to fastpath. You can contact us by clicking on my user name and selecting contact the mods.
John
Redbullracer
Message 3 of 6
Hi John just messaged my details over so I just hope my latency will be back to it's old self soon.
Regards Paul
JohnC2
Moderator
Moderator
Message 4 of 6
Hi @Redbullracer Thanks for that we will be in touch as soon as you form reaches the top of the queue.
cheers
John
PaddyB
Moderator
Moderator
Message 5 of 6
Hi @Redbullracer,
I gave your mobile number a quick call, I'm sorry I didn't get speaking to you today. I've tested your connection and its looking a lot better. I've carried out a SNR reset and changed your interleaving to fast. The interleaving should stay like this as long as the connection remains stable.
I'll give you a call again tomorrow evening to see how the connection is preforming.
PaddyB
PaddyB
Moderator
Moderator
Message 6 of 6
Hi @Redbullracer,
Thank you for taking my call. You connection is looking good, its been stable for the last 3 days with no drop outs reported during that time. Interleaving has been set to fast and it will remain like that as long as the connection remains stable.
PaddyB
