Message 11 of 12
Re: How do I get hold of BT to change my unlisted number to listed
@jimbrat91 wrote:
Yep called them but the options are not suitable - it is not a question about billing - so option 1 is out. It is not a fault - so option 2 doesn't help, I'm not moving house or leaving them and its not about mobile either - and none of the options has one for ' if its not one of these options hang on for an operator' either.
The closest option is billing. Regardless, if you select the wrong option you would have been transferred to the correct department.
Message 12 of 12
Thats what happened in the end - still frustrating
