Message 1 of 2
How do I get "Interleaved" to "Fast"
Hi There.
             I would like to have my latency type changed from "Interleaved" to "Fast" How can I do this.
1 REPLY 1
Message 2 of 2
Re: How do I get "Interleaved" to "Fast"
Hi I suggest you contact the forum mods they should be able to get you turned on to fast for you this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 72 hours
They are a UK based specialist team who have a good record at getting problems solved Hi I suggest you contact the forum mods they should be able to get your problem sorted for you this is a link to them
