ttyrie
Recognised Expert
Message 1 of 4
How do I get the IP Profile reset? It's stuck :(
Hello,
Had our Broadband installed 4 days ago, estimated speed was 17meg...
We are only getting 8.9meg at the moment, the IP Profile has stayed the same since I pluged the hub in 4 days ago. The speed we are getting is consistantly 8.9meg- which is as fast as an IP Profile of 9000 supports.
Tried phoning Technical Support (India) and they wanted me to go through the rigamorole of resetting the hub, restarting PC etc which wont reset the profile as it is an exchange issue.
The woman nextdoor is with BT and always receives well over 17meg...
So how do I go about getting the IP Profile reset?
Results Image not loaded
<script type="text/javascript">// paintProgressAndMessageOnBar(100,"The test has successfully completed" ); // </script> Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
8975 Kbps
0 Kbps21000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 8975 Kbps
 For your connection, the acceptable range of speedsis 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :12279 Kbps(DOWN-STREAM), 1147 Kbps(UP-STREAM)
 IP Profile for your line is - 9000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 4.0:17.28:78.72 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
Upload Speed
1139 Kbps
0 Kbps1147 Kbps
>Upload speed achieved during the test was - 1139 Kbps
 Upstream Rate IP profile on your line is - 1147 Kbps
ADSL Line Status
Connection Information
Line state:Connected
Connection time:3 days, 18:06:31
Downstream:11.99 Mbps
Upstream:1.121 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):6.0 dB / 6.0 dB
Line attenuation (Down/Up):23.9 dB / 10.6 dB
Output power (Down/Up):20.4 dBm / 12.0 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):13872 / 32
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):7805 / 7
Error Seconds (Local/Remote):890 / 0
And the line quality is very impressive...
Thanks 🙂
3 REPLIES 3
Message 2 of 4
Re: How do I get the IP Profile reset? It's stuck :(
you can contact the mods or just wait for the 3/5 period which you are more than halfway through.
the mods will probably get back to your in a few days
ttyrie
Recognised Expert
Message 3 of 4
I'll send them an email to get it reset 🙂
Message 4 of 4
by the time your request will get to top of list you will have completed your 5+ days and it will probably have reset on it's ownSmiley Wink
I don't think it's stuck but if it is at least you are already in mod queue
