fredd135
Message 1 of 4
How do I login to email?
I don't know if I have BT or Yahoo email. How do I find out which one I have? I have tried to find out using my BT primary username email address and account password, but I keep being told they are not recognised.
Can anyone help?
3 REPLIES 3
DanielS
Moderator
Moderator
Message 2 of 4
Re: How do I login to email?
Hi @fredd135,
You can find out which email you have by checking the address at BT Email Checker.
To get logged in, you should go to bt.com/mail or click on Email. I've included where you need to go below:
DanielS
fredd135
Message 3 of 4
Thanks for the advice, but I tried what you suggested before possting. I have just had another go in case there was a glitch last time, but no joy! I only have an @btinternet.com address which is my ID and keep being told it is not recognised. Can you suggest anything else?
pottyperson
Distinguished Guru
Distinguished Guru
Message 4 of 4
Try logging in here. If it works you can bookmark it instead of going to MyBT.
