Yankycrank
Message 1 of 5
How do I open VPN port?
Struggling to connect to my company VPN from home.  Anywhere else, fine - home? Nada..  Can anybody tell me how I open VPN port in my v1.5 homehub, please?
4 REPLIES 4
Distinguished Guru
Message 2 of 5
Re: How do I open VPN port?
I can't help with the opening of the port for your VPN
but it could be down to the BT Web Address Help...
Try typing in a random url, for example - http://www.whatisbtwebaddresshelp.co.uk
You should see an error...but you might notSmiley Indifferent
Anyway, click this link to check your opt in status - http://preferences.webaddresshelp.bt.com/selfcare/preferences.cgi
Click disable and see if your VPN now worksSmiley Wink
-+-No longer a forum member-+-
Yankycrank
Message 3 of 5
Thanks for the response DS - it is genuinely appreciated! However, I did that two weeks ago, doesn't work, and am still trying to find the answer.  'Customer support' simply tells me to upgrade to HH2.0... but won't gurantee that I will then be able to access my VPN!
Distinguished Guru
Message 4 of 5
I'm outta my depth with VPN'sSmiley Sad
Keep an eye on this thread though, as ya never know if another customer knows what to do....
minusdot
Recognised Expert
Message 5 of 5
My work VPN always just works. I'm on a HH2 now, but I was on a HH1 previously. Is it the standard Microsoft VPN? Exactly what issue/error are you having?
