Message 1 of 6
How do I synchronise my BTinternet.com calendar with my MS Outlook on my Android?
Currently my Windows 10 Outlook BTinternet.com email and calendar work fine and the same BT email account synchronises with my Android on MS Outlook. So far so good :)...........
I now want to synchronize my calendar between my Windows 10 Outlook and my Android, please confirm how this can be achieved.
I'd really appreciate your help on this and thanks in advance.
Best regards,  John
5 REPLIES 5
Message 2 of 6
Re: IHo do I synchronise my BTinternet.com calendar with my MS Outlook on my Android?
Have a look at this link. It might help.
https://www.bt.com/help/email/we-ve-updated-your-email
Message 3 of 6
Hi gg30340. Thanks for your response but the article only considers iOS and not Android. I don't know how to set up a DavCal account on my Android.
Anonymous
Not applicable
Message 4 of 6
If you have an Android phone then you may want to consider using the Google calendar, synchronisation between all of your devices couldn't be easier than doing it the Google way
Message 5 of 6
I use the Google calendar on my Android devices so I don't have any first hand knowledge of using the BT calendar.
I my be wrong with this but going by a quick Internet search the Android operating system does not natively support CalDav so it would appear that you  need to install a CalDav app in order to get your calendar to synchronise through that.
Message 6 of 6
OK, many thanks V_Meldrew 🙂
