Message 11 of 18
Re: How do i stop others using my wireless connection?
Qiote:
Although this will prevent casual intrusion, the MAC Address unfortunately is transmitted with every packet so it is not any deterrent to a "script kiddie" or attacker determined to compromise your network.
Episode #11 should explain the basics.
http://www.grc.com/securitynow.htm
I completly agree but it does put up another wall for those would be casual hackers that are just after free wifi for 20 mins 😄
There isnt much that would prevent a determind hacker from getting into your router. short of going over board with hidden SSID, really really long WPA2, MAC filterring and MAC spoofing (okay for home network) your prety much left with stickly IPs / Statick IPs and radius servers and server software for just this task. not sure the average user would want this much security for their home network 😄
_______________________________________________________
If I've helped, just click the Star - Every little bit helps 🙂
If you can't fix it with a hammer, you've got an electrical problem.
Message 12 of 18
omg paranoia over load!!!
It you use the reccomended settings, ie password, you will be fine.
There arent people scouring the streets trying to hack into wireless, even if they are, the only way to stop a determind hacker is to switch off wireless altogether.
------Marc------
Recognised Expert
Message 13 of 18
Why use a long & complex password/passphrase.
Common sense dictates, nothing to do with paranoia.  Smiley Indifferent
It depends how much you value your Personal or Business information or how much it may cost you if anyone uses your connection for the wrong purpose!
Try to keep ahead of those who will take advantage.
For instance Technology never stands still!
"I have this awful feeling someone is watching every move I make (one of my pet hates is router location tagging)." Marvin (A paranoid Android)
Message 14 of 18
The same could be said about the reg. number of your car, or the risk of your home being burgled and your bank info being pinched.
Its paranoia overload all this talk of people hacking your accounts and blah blah.
If you have a password that only you know on your wireless, and a fire wall, virus checker on your computer, your gonna be fine.
------Marc------
Recognised Expert
Message 15 of 18
@ Paigntonian
It's OK you can use your Car Registration Number as your WPA-PSK phrase.
I wouldn't recommend that you do so though.  Smiley Tongue
Message 16 of 18
I struggle to remember my passwords...... let alone my  car reg as well lol
------Marc------
Message 17 of 18
I wonder also how can I stop BT FON and Openzone using my Infinity connection. Seems to be part of the install, though I wasn't told.
Expert
Message 18 of 18
Hi there,
Have a look at this thread regarding disabling BT Fon on the Home Hub.
I hope this info helps. 🙂
