rajinderpauluck
Message 1 of 1
How do you temporarily disable HIPS in BT NetProtect Plus?
Hi all,
Does anyone know how to temporarily disable HIPS in BT NetProtect Plus? Basically we want to do a malware check using Zemana AntiMalware Portable on all PCs that have BT NetProtect Plus installed but an error message comes up saying that HIPS is enabled on the PC when initiating the install wizard and instructs you to turn off HIPS before initiating the install again. We don't want to temporarily uninstall BT NetProtect Plus if we keep help it but if that's what we need to do in order to allow Zemana AntiMalware Portable to install then fair enough. Zemana AntiMalware Portable will be uninstalled off each PC when finished. Your help would be much appreciated.
Kind regards,
Paul
