IanC
Recognised Expert
Message 61 of 67
Re: How does the BT Fon app work?
(much snipping throughout - this discussion is getting too unwieldy, and I'm running out of colours...)
[DS]
So you agree that the app controls the wireless manager?
Of course I agree - it's what I've been trying to tell you all along !
[DS]
(Sorry for not making this clearer before)
At least we got there in the end 🙂
[DS]
But yes I fully understand and accept why you said the manager makes the connection.
Erm...because it does ?
[DS]
The wireless manager makes the connection by being asked/made/forced(?) to do this by the app (read above)
Hallelujah !
The other point that you seem hung up on is the app looking for the state of the wireless interface. When I asked before how you think it could know that a Fon access point was available, and could therefore be connected to and logged into, you replied “via the login part…”
Until you can explain how a login can take place, without looking (via WiFiManager) at the wireless interface, there’s really no point in continuing this particular point.
Re: your comment that:
[DS]
I'm sure I read that you "stand corrected" - I need to re read earlier posts to confirm
I'll save you the effort - I stand corrected in that I hadn't noticed that the app restarts when the wireless interface is started. Nowhere have I said that I see the same behaviour that you're seeing.
[DS]
From my own observations, the app fires back in after a few mins, even if the wireless interface has not dropped - checking the hubs event log does back up that it didn't drop, as did the visual notification on the phone.
So something is causing your app to behave abnormally, in which case it shouldn’t come as a surprise if your wireless behaves unusually. While uninstalling the app, or otherwise preventing it from being loaded, may cure your problem, it doesn’t identify the root cause of why it behaves that way.
And as for rooting the 'phone in order to run software that'll disable the package - I'd strongly advise anybody to first try the UI provided.
Distinguished Guru
Message 62 of 67
(Snipped even more, tis giving me a headache...)
Fair enoughSmiley Happy
[DS]
Sure is, it's this 'something' that maybe a mod could find out and answer...?
But my wireless is fine, auto switching between my hubs, connecting manually if need be, though not when the app is installed...
I know, I can only say it must be something within the app, that must be jiggering up my wireless manager.
I did try the UI first. Rooting was my last option for this problem, though having since found other apps (ie Ad Free), which also need a rooted phone to work, rooting works for meSmiley Wink
Though there is an app that allows safe rooting
(oh gawd, hope no one asks what this wonder app isSmiley Very Happy)
-+-No longer a forum member-+-
IanC
Recognised Expert
Message 63 of 67
That's a bold statement, and not one that I'd be prepared to make myself.  It's not unusual, when developing/debugging software & systems, to find an "issue" with one that only manifests itself in another.
There are ways to (relatively) safely achieve a similar result - eg temproot, but truly rooting the device will always contain an element of risk.  Safe isn't a word I'd ever use in conjunction with anything that involves messing with core /system files.
Distinguished Guru
Message 64 of 67
I know it isSmiley Sad, AFAIK I've ruled out anything pre installed on the phone and anything installed after that could be causing this, bar the app.
I guess I should of added "relatively safe"Smiley Sad
and included that it allows the user to root and then unroot their phone.
Crockhamtown
Message 65 of 67
Hello Keith_Beddoe
You said something that struck a cord.Viz. "There is an option to enable it to make an automatic connection, but I have that disabled."
I changed to BT's new router recently and picked up BT wifi by default. My wife has a Samsung Tablet and it drives her mad to find that BT wifi (aka BT Open Zone) takes precedence over our normal router. She dislikes BT Open Zone because she has to log in with my data which she keeps forgetting and then she has to navigate a complex website. She knows that she can go settings from the Desktop and click on the router wifi which will then take over and get to the google website. I get it in the neck because I don't know how to make it easy for her. I say it might be useful for when we go on holiday.
A long story. Actually all I want to know is can I disable the automatic connection? Can you help?
Message 66 of 67
can you not make your home network ssid the priority so it will connect to that first that way when at home it conencts to home network but when out it will connect to any BTWIFI signal it finds.
that is how my S5 and Ipads are set up
Crockhamtown
Message 67 of 67
Thanks imjolly
I think I fouled up on giving a rating. Wanted to give more than one. Also couldn't find "Mark as accepted solution".
