Message 1 of 32
How does this look?
1. Product Name: HomeHub5
2. Serial number: +076284+1402014913
3. Firmware version: v0.07.01.0235-BT (Type B) Last updated [Unknown]
4. Board version: 01
5. VDSL uptime: 1 days, 07:23:15
6. Data Rate: 19999 / 79987
7. Maximum Data Rate: 38753 / 128825
8. Noise Margin: 18.8 / 22.7
9. Line Attenuation: 0.0 / 12.3
10. Signal Attenuation: 0.0 / 40.1
11. Data sent/received: 6.1 GB / 29.8 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4GHz wireless network/SSID: BTHub5-****
15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4GHz wireless security: WPA2 Only (Recommended)
17. 2.4GHz wireless channel: Automatic (Smart Wireless)
18. 5GHz wireless network/SSID: BTHub5-G7MG
19. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5GHz wireless security: WPA2 Only (Recommended)
21. 5GHz wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 9c:80:df:**:**:**
24. Software variant: -
25. Boot loader: 0.4.3-BT (Fri May 30 23:34:17 2014)
31 REPLIES 31
Distinguished Guru
Message 2 of 32
Re: How does this look?
This looks good
Good to see your uptime measured in days also 🙂
If not, I'll try again 🙂
Message 3 of 32
Looks good but you may find that your max data rate and moise margin begin to drop as more people are added to your cabinet
Message 4 of 32
The line attenuation and signal attenuation is it normal to say 0.0 on both before the other numbers?
Message 5 of 32
My stats show the same
Message 6 of 32
It must be normal then for fibre
Distinguished Guru
Message 7 of 32
It's for upstream. Maybe too small to measure.
Message 8 of 32
Looking back at other 5a stats they are the same so more like a bug
Recognised Expert
Message 9 of 32
This looks as if the data reset at 4.3GB has been fixed on the HH 5 B.
Can anyone confirm this ?
Distinguished Guru
Message 10 of 32
Isn't that confirmation?
