ironman123
Recognised Expert
Message 11 of 14
Re: How fast is my connection?!
It will fluctuate due to the reasons I gave above about server load etc,but you are on a very good connection that is operating at very near the max after overheads that infinity offers.
tim1964
Message 12 of 14
How fast is your connection?
I'd say Very.
Just downloaded the 1GB file from thinkbroadband (as a direct download) linked to above and it took 9m31s so that's less than 20Mbps according to the site.
Not bad for a 76Mbps connection (insert sarcastic smiley here). Getting really fed up with the "BT must know there's a problem and will fix it....." excuses as we all know BT won't fix anything if it costs them even a penny.
Ironically I left BT for Sky when BT charged £5/month for w/e and evening calls when Sky were offering them for free.
I will be looking at Sky again when I get out of this "rip off" contract extention as by then they wil have a FTTC option.
Sage
Sage
Message 13 of 14
I'd say Very.
Have you started your own thread on the problem you have and contacted the mods yet?
Chaoss
Message 14 of 14
Mines
http://www.speedtester.bt.com reports it as 3Mbps down and 4up
http://www.speedtest.bbmax.co.uk reports it as 1237kbps down and 967kbps up
http://www.speedtest.net reports it as 2.37Mb/s and 1.12Mb/s up
Your all so lucky with your double digit speeds
