kmitty
Message 1 of 10
How long after wholesale availability can orders be placed
In our street we've had the scenario of Exchange being Infinity enabled ages ago but no sign of our cabinet being upgraded and as such the availability date as indicated at his link
http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput
has continually slipped.
Finally that site is showing as 'Available' but:
1) The retail side of life (BT and my ISP) aren't allowing orders
2) The speeds as indicated by the site are very poor (about what we get at the moment!)
Anyone know what the above situation would imply about the likleihood of a decent fibre service any time soon?
9 REPLIES 9
Guru
Message 2 of 10
Re: How long after wholesale availability can orders be placed
I want to remember the online system is slower to update, I would advise trying to order over the phone. Though you won't get some of the free stuff when you order online. BT should also be able to tell you when they are going to start selling.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Sage
Sage
Message 3 of 10
IMHO If the ISP's are not accepting orders due to the speed issue then Openreach must not have released your cab for the service and it is awaiting problems being solved.
Could you give us a local postcode to check?
zagnome
Message 4 of 10
You might be too far from the cab. Do you know where your cab is?
Guru
Message 5 of 10
"The site is now showing as available"
zagnome
Message 6 of 10
Orders will be refused if the speed estimate is below a certain amount.
Guru
Message 7 of 10
Any amount can be ordered, Infinity is 15+
Faster Total Broadband will sell until it's the same as your ADSL connection
zagnome
Message 8 of 10
The VDSL2 estimate is the same as ADSL, for the OP. If he's a super long distance from the cab, there is no point moving to a new product if he won't notice a speed increase.
kmitty
Message 9 of 10
Postcode is RG40 3QS. Although having just checked the availability has since moved back to 19th Feb!
Sage
Sage
Message 10 of 10
See my post above.
