only2mb
Message 1 of 10
How long before speed increases after HH issues
Hi,
I encountered some issues last Friday (on Infinity up to 72mb package) with the HH dropping and a solid green light. HH has been replaced and I see that the speed is sat at 49mb where as previously it settled on approx 60mb. How long do I need to wait to see the speed attempt to increase again?
Seriously considering if the 72mb package is sensible anyway and if I would be better off with the up to 54mb package considering I never get anywhere near 72 anyway?
Cheers
9 REPLIES 9
Keith_Beddoe
Message 2 of 10
Re: How long before speed increases after HH issues
Which BT Home hub do you have?
Webby
Message 3 of 10
Could be days, weeks or months.
only2mb
Message 4 of 10
currently have BT Smart Hub (aka HH6)
Keith_Beddoe
Message 5 of 10
Can you please post the information from the smart hub, using this link.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
only2mb
Message 6 of 10
It's been at 49mb since Friday (router replaced this morning)
Product name:
BT Hub 6A
Serial number:
+084316+NQ63421139
Firmware version:
SG4B10002244
Firmware updated:
05-Apr-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 3 Hours 21 Minutes 19 Seconds
Data rate:
19.00 kbps / 49.00 kbps
Maximum data rate:
20242 / 61883
Noise margin:
6 / 10.6
Line attenuation:
15.9
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
75 MB Uploaded / 1470 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-2SQG
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-2SQG
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
88:A6:C6:1B:A3:7B
Software variant:
Boot loader:
7.33.1
Webby
Message 7 of 10
I'd switch to Infinity 1.
Keith_Beddoe
Message 8 of 10
You may eventually get to 61Mbs connection speed, but it would need a long error free period before DLM may change its mind.
Wht was the speed range that you were given when you signed up to Infinity 2?
only2mb
Message 9 of 10
to be honest I cannot recall the speed ranges that were originally discussed. I seem to recall it hitting around 62 at one point but that was short lived.
I think I will gather up all the issues I have had (of which there have been many) and speak with BT to adjust package. I can to some extent accept the lower speed, but not with the package I curently have.
Keith_Beddoe
Message 10 of 10
Probably due to errors on the line, or errors induced within your own wiring.
