ady199
Message 1 of 6
How long does it take for BT to investigate a fault??
I logged a fault with BT on 24/4/12 re: slow Infinity 2 speeds - I've just checked the current status of the fault and it's showing as:-
How long does it normally take for BT to investigate these types of faults???
5 REPLIES 5
Aarong
Guru
Message 2 of 6
Re: How long does it take for BT to investigate a fault??
I had the exact same issue a few months ago, since the fault is classed as open it could be anytime, it could be a day, a week or a month.
Although, during this period i didn't find any issues with my speeds.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Webby
Message 3 of 6
Depends on the nature of the fault, which team is responsible for the faulty kit/system/service and what their ERT (expected response times) are.
jussa21
Message 4 of 6
My fault is the same started 24/4/12 still open and still on number 1 bt retail
peapod
Message 5 of 6
Hi
My fault was reported on the 14/4/12 and they said it was fixed yesterday......guess what....its not!
good luck!
ady199
Message 6 of 6
Just looked at my reported fault and its still showing as Number 1, its now been 8 days since I reported the problem. I have sent 3 tweets now to @btcare and have not received a reply.
HELP!!
