Message 11 of 18
Re: How many attempts at fixing my slow speed do BT need?
something odd then as that is the hub address for access
wolosp
Message 12 of 18
OK, I'm now able to connect to the hub wirelessly after shutting down my work apps and disconnecting from the VPN.
ADSL details from the Hub are -
ADSL line status
Connection Information
Line state    Connected
Connection time    3 days, 04:49:58
Downstream    2,816 Kbps
Upstream    448 Kbps
ADSL Settings
VPI/VCI    0/38
Type    PPPoA
Modulation    G.992.1 Annex A
Latency type    Interleaved
Noise margin (Down/Up)    13.0 dB / 16.0 dB
Line attenuation (Down/Up)    56.3 dB / 31.5 dB
Output power (Down/Up)    4.6 dBm / 1.3 dBm
Loss of Framing (Local/Remote)    0 / 0
Loss of Signal (Local/Remote)    0 / 0
Loss of Power (Local/Remote)    0 / 0
FEC Errors (Down/Up)    6952 / 151
CRC Errors (Down/Up)    8629 / 126
HEC Errors (Down/Up)    30440 / 121
Error Seconds (Local/Remote)    4192 / 137
Message 13 of 18
your noise margin seems a bit high at 13 as normal about 6 but your line appears stable with a connection time of over 3 days.  your profile is abviously stuck at 135 as should have changed by now so I suggest you email the mods for assistance with your account and phone number and a link back to this thread forum.moderation.team@bt.com
wolosp
Message 14 of 18
Thanks for your help - I'll do as you suggest, perhaps the mods can get things moving a bit quicker than the BT Helpdesk chaps! I'm pretty fed up after a month of 135k download speed.
Message 15 of 18
the mods have a good track record just needs some patience and they will contact you
wolosp
Message 16 of 18
Patience????
I've needed plenty of that during this last month! Smiley Very Happy
wolosp
Message 17 of 18
BT have scheduled an engineer to look at the exchange / outside line on Monday, and I've not had a reply to my email to the mods, but this morning I find that my profile has suddenly gone up from 135kbs to 2000kbs - i.e. the speed it should be running at!
Soulvache
Message 18 of 18
Let's hope it stays like that for you! Smiley Happy
Kyle
If you found my post helpful, please give Kudos on the left!
