Pembo
Message 21 of 33
Re: How many more years will I wait for "proper broadband"?
hey guys,
just done a test on the sky website and they I've recognised the fact I've got a very poor connection speed:
http://www.flickr.com/photos/63624851@N08/5803708507/
We had BT vans down are road on Sunday morning but I've not seen any improvement on the line speed...
I checked the noise levels also and they are slightly up at 13/13.5
ive still not been on the phone with the engineers because I've not got the time to sit on hold for 15-30 Minis and then wait around for a call back!!
Si
Message 22 of 33
is your connection still holding stable?
Pembo
Message 23 of 33
hi jolly,
Yea I think it is, I will upload a full status report when i get home.
Cheers
Si
Pembo
Message 24 of 33
Uptime:4 days, 19:22:55
Modulation:G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]:448 / 1,600
Data Transferred (Sent/Received) [MB/GB]:181.56 / 1.58
Output Power (Up/Down) [dBm]:11.5 / 16.0
Line Attenuation (Up/Down) [dB]:31.5 / 58.0
SN Margin (Up/Down) [dB]:13.0 / 3.0
Vendor ID (Local/Remote):TMMB / ALCB
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):4 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):7,774 / 0
FEC Errors (Up/Down):0 / 6,590,064
CRC Errors (Up/Down):0 / 317,825
HEC Errors (Up/Down):0 / 299,458
Line Profile:Interleaved
Message 25 of 33
still holdingSmiley Wink  noise margin dropped a lot
Pembo
Message 26 of 33
I was having trouble with my xbox lastnight. At first I had no connection to my hub after many try's I got an Internet connection then eventually connected to xbox live. I think this was because the wireless router is quite far away from the xbox. Ive swapped my wireless adapter on the xbox an it seems OK now but I wounded if I should Invest in a better router to improve my connection?
Uptime:6 days, 16:40:33
Data Transferred (Sent/Received) [MB/GB]:486.45 / 2.34
SN Margin (Up/Down) [dB]:13.0 / 13.5
Error Seconds (Local/Remote):11,794 / 0
FEC Errors (Up/Down):0 / 10,530,079
CRC Errors (Up/Down):0 / 490,241
HEC Errors (Up/Down):0 / 463,211
Message 27 of 33
still holding and noise margin gone back up again - at least stable now
Pembo
Message 28 of 33
My Xbox is telling me I must reset the router because my NAT type is set to Strict. I just wanted to post a record of my connection time ect and also ask if anyone knows why the NAT setting has changed
Si
Uptime:10 days, 20:34:37
Data Transferred (Sent/Received) [MB/GB]:676.38 / 3.22
Error Seconds (Local/Remote):16,337 / 0
FEC Errors (Up/Down):0 / 14,645,258
CRC Errors (Up/Down):0 / 681,899
HEC Errors (Up/Down):0 / 644,495
Pembo
Message 29 of 33
Hi,
been getting a some very differnt results since I reset my router, the line speeds have been getting higher but the line now seems intermittent....
Uptime:0 days, 1:48:21
Bandwidth (Up/Down) [kbps/kbps]:448 / 2,560
Data Transferred (Sent/Received) [MB/MB]:7.71 / 127.14
Output Power (Up/Down) [dBm]:11.5 / 17.5
SN Margin (Up/Down) [dB]:13.0 / 11.0
Loss of Signal (Local/Remote):8 / 0
Error Seconds (Local/Remote):5,737 / 0
FEC Errors (Up/Down):0 / 100,905
CRC Errors (Up/Down):0 / 7,808
HEC Errors (Up/Down):0 / 3,682
I'm very happy to see the line speed so high and ive not had the line drop while ive been online yet.
My current line speed:
http://www.speedtest.net/result/1342074783.png
Pembo
Message 30 of 33
Hey guys, Its been a while since my last post but I'm having some download speed problems. Our line was resently cut off for 5 or 6 days and since that we've been getting flutuating line speeds 😞
I think the line speed is going from 0.20 upto 2.2
Any thing eles you guys can tell me who be much appreciated
