Message 1 of 7
How much advance notice do I need to give to get Fibre installed?
I am going to be moving to the UK in September and want to have my internet services up and running as soon as I arrive at my new house in CM2 8ZG, Great Baddow. I would like to know how much in advance do I need to book a fibre installation?
6 REPLIES 6
Message 2 of 7
Re: How much advance notice do I need to give to get Fibre installed?
2 weeks should be enough  but I'd give it 4 to be on the safe side.
Message 3 of 7
Thanks...
Message 4 of 7
@LWGray
Who is going to provide your service?
Message 5 of 7
I have no idea. I assume BT install it?
Message 6 of 7
No, its Openreach that install it, not BT Retail.
You will have to choose a provider, and place an order with them a couple of weeks before. Bear in mind that fast broadband is not available everywhere, so you may have to accept standard broadband.
This is a BT Retail customer forum, so if you choose a different provider, then it would be a good idea to read any posts on their user forum, before making your choice of provider.
Message 7 of 7
OK. Thanks for the heads up.
