gringo1804
Message 1 of 5
How to add another router to Home Hub network.
Hi,
Hope someone can help.  Here's the problem.
I have a Home Hub downstairs, which is working fine.
I want to put a desktop computer, which doesn't have wireless, upstairs, in a room which I can't get an ethernet cable to easily (we have vinyl floors, due to an allergy problem, therefore no carpets to run cables under).
I have a spare NetGear DGN2000 router, which says that it can be used as a wireless repeater.
I would like to use the spare router as a bridge or access point, linking wirelessly to the Home Hub, to enable me to connect the desktop via ethernet, and to improve wireless coverage upstairs.  I know I could use Homeplugs to get the broadband connection upstairs, but I have the router sitting around doing nothing, so would like to make use of it.
I have a couple of laptops running Vista, the desktop is on XP.
I am fairly IT & network literate, but have looked at the settings and spent ages googling this without finding a clear solution.
Can someone please help?
Many thanks,
Gringo
4 REPLIES 4
Message 2 of 5
Re: How to add another router to Home Hub network.
don't think it works with hh2
try here  http://www.jarviser.co.uk/jarviser/homehubindex.html
goral
Message 3 of 5
I connect my D-Link DIR-516 straight to one of four RJ45 (Ethernet) socket.
In router put this cable to WAN socket. It working very well.
Router DIR-615 used BT Home Hub 2.0 like cable modem.
Distinguished Guru
Message 4 of 5
If you are using a version 1 or 1.5* hub, then yes you can connect them by wireless.
As imjolly said, you can't do this with a v2.
but
You can when using homeplugs.
Look for "Link two....." on the link imjolly provided.
*1.5 can reset when using WDS.
-+-No longer a forum member-+-
meaga-byte
Message 5 of 5
Just be aware that bridging your two routers wirelessly will effectivly half your throughput!
It would be better to connect the two via cable and have the second acting as a standalone WAP.
I know u said cable runs are a problem but maybe have the second router in the landing or at the top of the stairs?
When using my homehub to do just this i had to buy a second router (netgear) to ask as a promary router (DHCP / DNS etc) and used the HH as WAP.
_______________________________________________________
If I've helped, just click the Star - Every little bit helps 🙂
If you can't fix it with a hammer, you've got an electrical problem.
